Just got a Imax B6A2 V2 charger. The included instructions are just about worthless, Got on Youtube and found a lot of helpful info. But never could find out if this charger shuts off automatically. Or do you have to watch the voltage on the screen and when it reaches the correct voltage shut it off manually. Charge mostly 3,4 and 6 cell batteries.
Imax B6AC V2 charger
Originally posted by exf4mech View PostJust got a Imax B6A2 V2 charger. The included instructions are just about worthless, Got on Youtube and found a lot of helpful info. But never could find out if this charger shuts off automatically. Or do you have to watch the voltage on the screen and when it reaches the correct voltage shut it off manually. Charge mostly 3,4 and 6 cell batteries.
I have the same charger and works great. Get a LiPO charging bag or a Bat-Safe charging case and use it. I know some people use steel ammo cans as well to charge their LiPOs. I have both so take my LiPO in a charging sack and the I have empty sack the put used LiPOs in at the flying field.
1 Photo
Some LiPo charging fires I know of were proven to start in the charger due to blocked cooling vents.
Those little "feet" on the charger are there to provide an air space under the charger and they need that space.
Put the charger on a hard smooth heat resistant surface. I set mine on a spare 12 inch square ceramic floor tile.
Setting the chargers on carpet or an upholstered chair was the source of 4 fires. (fortunately one set on a standard desk chair just burned the chair.)
Its not hard to charge safely.
