I'm building a Trex 500X as a low head speed project , instead of using a 6s 3300mah I will be using the largest 4s battery that will fit. According to the weight and dimensions listed on MOTION RC, the Admiral 4S 5000's will fit. If somebody has these batteries could you verify the dimensions listed are accurate. Thank you.
Weight | 482g / 1lb, 3.80oz |
Length | 155mm / 6.10in |
Width | 46mm / 1.81in |
Height | 30.25mm /1 .19in |
