Lipo Balancing
  • Lipo Balancing
    When balancing lipo batteries. They should balance out pretty close to even ie: 3 cell 4.2 4.19 4.2.
    With that said, when should you be concerned when battery cells are NOT close when doing a balance charge???
    Example: 3 cell, 4.2 4.19 4.13.  Is the difference in this example be of great concern??
    Thanks,
    Lon
    PS: Yes, I have a battery with the example readings.
    Lon
    RE: Lipo Balancing
    Try discharging in storage mode, and recharge see if that helps.
    Flight Risk (Sean)
    AMA # 986105
      RE: Lipo Balancing
      it worked!!!
      Lon
        RE: Lipo Balancing
        Cool Beans!
        Flight Risk (Sean)
        AMA # 986105
          RE: Lipo Balancing
          Hey Lon
          Hows the hand doing? Sounds like your getting back into it already
          Jeff
            RE: Lipo Balancing
            Jeff,
            The hand is doing much better.  Remainder of the stitches removed last week. Hand is sensitive now to the cold, and I'm doing things to get full movement back in the little finger.  Respect that prop when powering up and working on planes.  All my planes in the hanger now, are displayed without the props. So when I pull one down to fiddle with and power it up to do/check servos and retracts. That hazard isn't there.  Thanks for asking.
            Lon
            Lon
