How about using and adapter on it? Will you still have the same performance as to using the correct end?
Admiral 3S LiPo - Lack of high mAh packs
Originally posted by Pauly View PostHow about using and adapter on it? Will you still have the same performance as to using the correct end?
I use adapters on a regular basis, usually for charging other people's batteries with my field charging system. This is a lower load on the adapter and less likely to fail.
The adapter does not avoid the current limit of any type connector being used in the system. If the concern is the current limit of Deans, expect that concern to be the same with the adapter.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
- 1 like
Just under a month away from the proposed target arrival of these new 3S 5000 batts
https://www.motionrc.com/collections...-ec5-connector
Hope you have a grunch of the same mAh size/ EC5 config 2S that are OOS coming in also.
https://www.motionrc.com/collections...ttery-with-ec5Warbird Charlie
Incinerator Loss 16
Hello Tom...............Any schedule update for this highly anticipated 3S 5000mAh 50C new product.Warbird Charlie
Incinerator Loss 16
Originally posted by dkalwishky View PostI just chatted with Wayne, here is what he told me.
"Dave Office Manager says Battery shipment due in the next 2 weeks so hopefully they sent them with it. They are supposed to be in there"Warbird Charlie
Incinerator Loss 16
Originally posted by Tom.MotionRC View PostYes, about 2 weeks is correct. Could be a little sooner if everything works out but figure 2 weeks to be safe.little by little I am coming back from the inferno.
Incinerator Loss 16
I like that pic Dan...................saving it to the PC in jpg format for use on a banner inside the new garage where the fleet will hang
Incinerator Loss 16
Originally posted by Grossman56 View PostOne picture says it all!
Great to hear the hangar is on track, how did you make out with the truck and trailer??
Grossman56Vehicles..... See post #29
Incinerator Loss 16
THANX Tom............Order #387468 placed for 6 of them which is half of what I need but it's a start on the support equip replacement programWarbird Charlie
Incinerator Loss 16
