I'm trying to discharge a few lipos and I have never really done this. I've gotten some 2200mah 11.1 3s and 3300mah 11.1 3s. My charger on goes to 1.0a 9.0v for a 3s Lipo. Is this correct for both batteries in a discharge mode. It will go lower on the mah, but not higher. This is a DC-6 charger by Dynam.
Discharghing a Lipo? Questions needed
Mine only goes as far as 3.0V per cell when discharged, so I don't know. I figure 9V is still quite a bit of voltage in a battery. A friend of mine rigged up this set up: He got himself a DC lightbulb with the accompanying socket. Put on an EC3 connector and he hooks up the battery to it and let it drain completely till the light goes out. Then into the garbage or the Hazmat bin at the firehall, even though they say you don't really need to treat depleted LiPos as hazardous material.
I always take the easy way out for discharging and put the pack in a plane.
I have my ESCs set so I can just run at WOT to LVC and the packs will be right at 3.7v/cell when they cool off.FF gliders and rubber power since 1966, CL 1970-1990, RC since 1975.
Originally posted by Pauly View PostI thought I was going to fly some, but it looks like I want be able to for a week or so. I have them all fully charged. Just going to store them a week or so or should I even worry about it?
Steve
AMA 95495
Freewing P-51D Iron Ass
Freewing F-86 80MM
There's several schools of thought on storing and charging lipos. Some say you never leave them fully charged for more than 48 hrs because it's hard on the lipos, others say it's no problem to leave them indefinitely. On discharging most will agree to discharge to between 3.85 and 3.90. I error to the side of caution and discharge to 3.85 after 48hrs.
I always storage charge my batteries if I'm not going to fly for a week. I prefer to fly them down to storage voltage. About five minutes of flying for the way I fly. It's more fun than standing by your charger for ever, and it's faster. I also wonder about wear and tear on the charger. It seems to work pretty hard discharging. Doc
I hear you Doc, and good idea Steve, personally, with the weather being so iffy around here, wind wise. I usually have a couple of each charged and ready to go. When Fall hits, I drain them all down to storage mode. So far, they seem to be fine. It'll be interesting when the batteries have to be shipped at very low voltage, apparently this is going to affect the life of the battery. More Gov't regulation in the land of the free.
Grossman56Team Gross!
