Model Aviation Magazine
Graphine / Lipo Batteries in Motion RC's Future?
  • #41
    I just bought the 4's 5000 60 c and yes they are an 1 longer then the original but thin by a half an inch. My weather sucks here so hope to try them soon. using them in parallel for 8's for my tomcat 110 motor its going in my hanger 9 lancair legacy should be a great fit.
    • #42
      Thanks Twowingtj. BTW, we just doubled checked the weight of 5 different 4S 4000 packs. Most were at 388g and we had one at 394g. We weighed them on our calibrated shipping scales we use for small packages.
      • #43
        Thats very interesting information Tom. I am aware that carbon is a terrific conductor of electricity. They have been using carbon in the spark plug leads of car engines for many years. However Graphene is not a new material but it does have immense strength properties and its very light.
        Martin.
        • #44
          Have any of the dimensions on the Admiral Pro 6S 4000s changed? It was one of the only batteries that fit perfectly in my 500 heli. Otherwise, good news about the performance increase! Might have to look at a few battery purchases soon.
          • #45
            6S 4000 are nearly identical. I think the new ones are a couple mm longer and a few mm less thick with the same width
            • #46
              motion if you started carrying graphine batteries I would buy them, I have a few and like them very well. I prefer them over the admirals.
              • #47
                Hi...i am a new user here. As per my knowledge under fairly high discharge levels in EDF jets, they come back down barely warm to the touch, no swelling, holds cell matching well, cells balance charge nicely, IR maintains low reading under the same conditions, seem to have a more durable packaging and plates, and holds voltage well under load. I have no idea on longevity yet because they are still somewhat new to me, so I need many more flights on each pack to see whether they hold true to their advertised longevity specs. This is coming from someone who's not a biased LiPo brand individual too. If I try something and it works out, great, I'll keep using it until it doesn't. I have only tried Turnigy Graphene batteries though in two different sizes for different applications, a 4S 1300mah 65C, and 6S 5000mah 65C. One thing I hope that doesn't occur is LiPo brands advertising their non Graphene related LiPo's as Graphene related LiPo's.
                assembly circuit
                • #48
                  Hello LulaNord and welcome to the Squawk,
                  Your hope is most understandably felt by many but as it stands there is no true graphene battery developed yet. Here's a good starting reference in case you didn't read all of this thread.
                  https://www.hobbysquawk.com/forum/el...4485#post64485
                  ScaleTech OV-10 Bronco; HSD A1 Skyraider(in rehab shop); FlightLine: F7F-2D, P-38 Allied Green, Sea Fury; FMS 1400: P-40B, P-51 Marie, F4U Olathe, F6F, T-28, P-40E, 1500 Razor, 1700 F4U and a Fox glider; Freewing: A-10 Artic Thunder(100+ parts to rise again), A-6, P-51 Iron Ass; VQ: P-39, JU-52; LX PBJ-1(B-25); Dynam: ME-262, FW-190, Waco, Catalina; Phoenix Spitfire; Maxford Antonov AN-2; Starmax L-4 Grasshopper; Eflite 1100 T-28 float; Tech1 P40;
                  • #49
                    What's the dang deal? I have 4 flights on my new Admiral 4s 3600mah and capacity is still 4200mah compared to other brands which typically measure quite close to spec capacity. Am I just lucky with this one lipo or are these things really better?
                    • #50
                      @Zep: How are you measuring capacity? First, you should never discharge to low Voltage cutoff (LVC), second, if you want your battery to last, you should not discharge to lower than about 3.7-3.8V per cell (14.8V total), after resting a few minutes after use (~15-20% charge remaining). That means your charger should show no more than about 3000mAh returned to the battery during charging.
                      • #51
                        WintrSol. I am measuring capacity on Turnigy Reaktor charger. I fly from full charge down to >25% capacity remaining then after cooling charge to 4.2V/cell at 1C rate. I ignore capacity restored to battery. Then I use charger discharge mode at 20 watt limit down to 3.0V/cell at which point the charger terminates and displays capacity removed. Capacity displayed is about 4200mah after 4 flights. When I measure capacity of new Electrifly,Turnigy Nanotech, blue and Zippy lipos in this manner I get much closer to their advertised capacity. After many flights, some abusive, these lipos show significantly reduced capacity as expected so it will be interesting to see how the Admiral holds up.
                        Zep
                        • #52
                          3V/cell is a bit on the low side for me and I consider such batteries to be nearly "dead", which is a bad thing for LiPos. When I've "overflown" a battery down to that, I fear I've nearly destroyed it and whatever lifespan is left is greatly diminished. Why do you feel the need to discharge them down to 3V/cell after use? I've not heard of measuring what comes out. Most people measure what goes back in and rarely allow voltage to go much below the recommended storage voltage of ~3.75 - 3.8V.
                          • #53
                            I do not fly my lipos down to 3V/cell, only discharge to 3V/cell at very low current on my charger. I do this very infrequently to check health of my lipos. Discharging down to 3V/cell at low current will not damage lipos, they don't even get warm. As I said when I want to measure capacity I use the charger discharge mode which discharges to 3.0V/cell at low current. Discharge power is limited in the charger to 20 watts therefore current is roughly 1.2 amps for a 4s.. I have found that measuring what goes back in gives inconsistent estimate of lipo true capacity. You need good estimate of how much you took out before measurement of what you put back in has any meaning.
                            • #54
                              Who told you that? Discharging to 3V/cell at any rate causes ion migration at the surface of the electrodes, which increases internal resistance; cell temperature is not an indication of damage. Each time you do this, you reduce the amount of current you can draw, and increase the temperature of the battery during flight.
                              Next question: do you go through the discharge as soon as the charge cycle is complete, and, do you use the balance mode of the charger? Just curious, as a 10% capacity over the pack rating is a lot to expect from a temporary surface charge.
                              • #55
                                I have never heard of this practice with LiPos but hey, if that's what you believe, who are we to tell you otherwise. For me at least, this is not a way to determine battery health. Not getting warm doesn't mean anything. I've discharged batteries down to zero using a light bulb (before disposal). They don't get warm then either.
                                • #56
                                  No one told me that but look at these links which mention discharge down to 3.0V. Who told you that discharging at 0.33C to 3.0V/cell just a very few times will significantly reduce battery performance?
                                  http://batteryuniversity.com/learn/a...ased_batteries
                                  http://batteryuniversity.com/learn/a...acteristics_li
                                  Also see attached excerpt from Hitec X4 AC Pro charger manual showing lipo discharge voltage down to 3.0V/cell. My Turnigy charger manual says same thing and in fact is programmed to discharge to 3.0V/cell. Internal resistance of my Admiral 4s/3600mah is still at about 4.5 milliohms/cell after 4 flights as expected for new lipo of that type. I get the ion migration part but let me say again that I perform the 3.0V/cell discharge test very infrequently so as to avoid permanent damage. I did it on this lipo twice only because initial capacity was way over spec and I wanted to verify.
                                  After charging at 1C rate in balance mode I let the battery sit for a few minutes before discharge.
Name:	Hitec X4AC Pro.JPG
                                  • #57
                                    Well, if you can be sure that no cell in a pack goes below 3.00V during discharge, you can get away with it.. Does your discharge tool monitor all cells, and shut off when the first cell is at 3.00V, even if the other cells in the pack are higher, or does it discharge to a total pack Voltage of 3V times the cell count?
                                    • #58
                                      Yes, my charger terminates discharge when the lowest cell gets down to 3.00V, not 3.0V times cell count. Just to be safe I may set cutoff voltage to 3.2V. I made a few discharge curves on older lipos and found not too many milliamp hours left after voltage goes below 3.2V/cell anyway. Thanks for the input.
                                      But I would still like to know if anyone gets more capacity/flight time with Admiral lipos or found them to be otherwise superior to other brands.
