National Air and Space Museum
Admiral RX600SP 6-channel DSMX with Stability Plus Gyro
  • #41
    Originally posted by TwistedGrin View Post
    Gents - I often use a separate system (RC+Stabilizer) and have a dedicated UBEC plugged into the "BATT-Bind" port of the RX for power which isolates the ESC for just running the motor. This affords the ESC to stay cool as it is now only servicing control to the motor. Can we deploy a separate UBEC power lead to this RX bind/Aux2 port for the same purpose?
    Thanks in Advance,
    TwistedGrin
    Yes you can. I use this rx on my F4 and B24 both of which use an external bec.
    • #42
      10:4 Excellent - TG
      • #43
        Gents - I want to deploy this stabilizer in a small plane that requires bottom side installation....this requires the stabilizer to be mounted facing to ground during normal flight. As it stands now....it wants to roll over as if it is in recovery mode....however when the plane turns inverted all surfaces move correctly. Is there a dip switch or combo of dip switch to tell the stabilizer it inverted normal?
        • #44
          Not that I know of. Are you sure it's not in recovery?
          i wonder if binding it while installed inverted would do anything.
          • #45
            Ya I might try binding inverted next week and see what it does.....
            TG
            • #46
              UPDATE - Yes it will work facing to the ground.
              1. Bind as usual
              1. Configure Gyro as mode (C) / On-Off toggle
              2. Mount to plane pins facing the ground / Pin Connectors forward to nose
              3. Power up and check Stabilizer throw direction
              4. Diconnect power
              5. Re-Mount stabilzer facing the ground / Pin Connectors rearward to the tail
              6. Check Stabilizer throw direction
              TwistedGrin
              • #47
                Hey guys ,I have an rx600 on my turbo jet which has about 6 flights on it now.
                today I went to fly it and the gyro would not initialize.
                the reciever worked great flew with no issues.
                It started working all pf tje sudden when I installed the 3rd pack and worked fine for 3more flights.
                Any thoughts?
                (sorry for run ons)
                • #48
                  I have noted that mine did the same thing once....but observed that during my battery hook up I had several failed solid Deans connector hook up whereas ...when hooking up the battery the RX was cycled rapidly several times and the stabilizer would not engage at final. Unplug the battery and wait a second or two...then make a clean positive battery connection. All good and normal stabilizer is present. Perhaps this could be a similar scenario??
                  TwistedGrin
