Admiral RX600SP 6-channel DSMX with Stability Plus Gyro
  • #81
    Originally posted by PAUL185 View Post
    I purchased this RX and put it in the Freewing 64mm Sabre. I flew it tonight and it got the speed wobbles bad. It looked like it was going to shake itself to death I slowed down to just above a stall speed and it settled out and I landed. I am new to programming a gyro so I figure the gain is too high. My question is how much do I turn the ailerons down? I guess I go counter clockwise but I have not seen any documentation on what the usable range is. It is currently set the way it came.
    Turn your gains down. Never use such a gyro RX on the setting it came with. Start at less than 25% and go up in small increments.
    • #82
      Thanks! Would 25 percent be approximately 9 o'clock?
      • #83
        You need to figure this out for yourself. Turn the pot all the way from one end to the other. That's 100%. Now estimate 25%.
        • #84
          Has any one used the RX600SP with the F-27 Evolution a delta wing from Horizon Hobby? If so what micro switch setting did you use for the stabilization mode?
