Foam Glue
  • Foam Glue
    Would like to suggest Beacons "Foam Tac" glue be added. This glue works great on all types of Foam.. Yes, even EPS foam !!!
    Rick
    Re: Foam Glue
    That Beacon glue is very good. I have been using Beacon's "Hold the Foam" for a couple of years. It is white and has the density of toothpaste and works well on EPO and most other types of foam and makes a solid bond with other materials like wood cardboard and even fabrics.
      Re: Foam Glue
      Yes, it seems Beacon is the only source for Foam safe glues ! I have an update about their Foam-Tac product.
      When applied to EPS foams, it still melts the foam!!! EPS is the worse material to repair. Gorrila glue is the only thing I can find that works well !!!!!
