Funtana .40 conversion
  • Funtana .40 conversion
    Can anyone recommend a power setup for my Funtana .40 size ? I will need a ESC, motor & prefer a 6S pack. I'm not into 3D, just use it as a knock around flyer.
    Weight: .................. 4–5.5 lbs (1.8 Kg–2.5 Kg)
    Glow Engines: ................... 32–.46 2-stroke, .40–.72 4-stroke
    Wingspan: ............. 56 in (1422 mm)
    Length: ................... 56 in (1441 mm)
    Wing Area: ............ 714 sq in (46.1 sq dm)
    Click image for larger version  Name:	HAN1975_a0 (2).jpg Views:	1 Size:	19.2 KB ID:	161819
    www.23T.weebly.com
    Just got one a month ago, and have installed a battery hatch up front. Figure on running either two 5S, 2200mah packs in parallel or a single 5S, 4000mah pack. The pack(s) will be Velcroed to the top of the wing. There is a new line of motors out ..BADASS motors.. available from either RC Dude or Innov8tive Designs (Lucien Miller). These motors seem to have a lot of power for their size and weight. I suspect their windings are able to withstand higher current.
    My "build" can be found here; http://www.halifaxelectricflyers.com...hp?f=20&t=5454
    Bill
      retiredVTT What is your AUW with the 5s 4000mAh? Are you staying with the stock scheme? I can't load your link, possibly because I'm in China.
        Thanks for your input guys. However, I have this plane up for sale.
        www.23T.weebly.com
