Opposite working retract
  • Opposite working retract
    I'm replacing one on my retracts in my Dynam FW 190 and as usual one works part time. I had an extra retract in the box and thinking it's an eflite I think, but the problem is they work opposite of each other. I have them both in the same position and when changed or plug the battery in one goes up one goes down. How can I fix this issue without the same manufacturer retract?
    Still Learning:D
    Use a signal reverser (click on the red link)
      What exactly is that OV? Is thst something I have order and hook between the servo leads?
      Still Learning:D
        click on the link and you'll see ;)
          Thank you OV
          Still Learning:D
            Do you have an extra channel you can hook a main into? You can reverse that one and mix the gear. I just found out the eflite EFLG 1590m is a drop in fit for that dynam retact. My marauder mains are the same as yours and i'v had to replace them both due to something stripping on the inside. The retract i just replaced a few days ago had issue with mid 40F temps. It devolped an odd delay. Contacted MRC customer service and they said cold weather something dynam working on. Might get another eflite. I suspect dynam parts wont be here till mid/end of jan when the blackwidow is expected.
              Thanks Rob, everyone is out of the retracts and I have heard that the Dynam retracts are bad for not working in colder weather. I talked to Hippie, today and he suggested to check with Horizon. I believe that'll be my next option. Thanks for the help.
              Still Learning:D
                Pauly........Have ya checked out the FlightLine 1200 sized etracts. The dimensions look darn close to the Dynams.
                I have over a 100 sorties on my Sea Fury without a single issue
                  I haven't checked on that or called MRC! I checked Horizon and a set was crazy on price. The reverser would be great, but the shipping is ridiculous being it comes from Hong Kong. Thanks for the info.
                  Still Learning:D
                    Try this servo reverser that is in the States if that's the route you want to go. Don't they have Google in Warsaw LOL
                    I don't understand why you think the shipping from Hong Kong is ridiculous.
                    I just bought a $4 bearing from HK out of Hong Kong and it cost $3.35 to ship which is pretty darn reasonable from half way around the globe.
                      Thank you OV, that looks better. I see speak with MRC and the one I spoke to wasn't sure about the Flightline retract. I'm thinking about the 3.0mm retract and just drill it out to fit the 3.6mm. I'm thinking it being a Dynam retract it should fit.
                      Still Learning:D
                        I guess the time to wait is my main concern on shipping. I'm impatient on that.
                        Still Learning:D
                        • #13
                          I had the same problem on my Freewing B-17. I removed one retract and switched the wires to the motor and that fixed the problem.
                          • #14
                            I have seriously thought about doing that.
                            Still Learning:D
