Spectrum DX6i binding to FMS T28 1400mm using Spectrum AR6210 Receiver
  • Spectrum DX6i binding to FMS T28 1400mm using Spectrum AR6210 Receiver
    - deleted -
    Re: Spectrum DX6i binding to FMS T28 1400mm using Spectrum AR6210 Receiver
    Sounds like the fail safe is not set on the receiver. You might have to rebind it. I use the same receiver in my 1400 t 28 and have not had any problems. Look at the instructions for setting up a failsafe.
      Usuall practice is to disconnect battery then turn off transmitter. Upon startup, turn on transmitter then connect battery.
