Ztw esc problems
  • #21
    Originally posted by OV10 View Post
    Did you get the 2 download files located here?
    https://www.motionrc.com/collections...ec#support-tab
    I downloaded the USB link ok and it will open. The firmware updater is a .xup and I don't have anything to open it. This computer is Windows 7 pro. I do have a laptop with Windows 10. Maybe that would open it?
    • #22
      Interesting...…….when I dl'd it moments ago it was an .exe labeled "SetupGeckoUsb_Software.exe"
      • #23
        Right, the USB setup software was an .exe and opened, intalled, fine.It was the firmware update for the Gecko that was a zip file .xup. I was able to unzip it but not open the .xup file to install it.
        • #24
          Ahhhh………….you meant the update and not the updater.
          Try this link from over on RCG, it is a thread that has instructions for the various firmware updates with links to the downloads from Altitude Hobbies which is where I got mine some 4 yrs ago.
          https://www.rcgroups.com/forums/show...s#post30402578
          Direct to Altitude page...……. https://www.altitudehobbies.com/coll...s/gecko-series
          Good luck
          • #25
            I went to Altitude Hobbies page and when downloaded it is also the .xup file.
            • #26
              Is it just the Gecko that has the problem? Or do the Mantis and Beetle do it too??
              • #27
                Just the Gecko. Did you follow the instructions over on the RCG link??
                • #28
                  Thanks for the information. I just received an 85A Mantis from Motion. I will try it in one of my planes that have the 85A Gecko. I did follow the link and when I got the file it was the .xup. I have the installer dashboard installed. That was standard .exe file. If you google it there are several programs you can download that will open it however most are not recommended. I asked an IT friend to check and see how I can open it safely. I am not computer savvy so I could be missing something.
                  • #29
                    Funny thing. I had ordered another Gecko from Motion and afterward (reading here) I had wished I ordered a Mantis. (I have a couple smaller ones that work fine) I received a Mantis and looking at my order it was for a Gecko. Lucky accident. I guess they use a crystal ball and knew what I really wanted.
                    • #30
                      Just bought 2 of these for a twin and am now having issues. on the bench just starting the motors up. about 2-out of 10 times, one motor will not start, but the other will run. I cant get them both to run until I completely throttle down. Its maddening as Ive tried all kinds of reconfigs with the battery, esc and Receiver to try to eliminate. I did a reset on both using the manual beep method. Maybe I need to adjust the timing? Or maybe just return them.
