This is a battery for my motorcycle, but I'm sure I'll get better answers from RC hobbyists than motorcyclists. I've never had a Lithium ion motorcycle battery last more than a year. It's likely my own fault, leaving the key on accidentally and discharging too much. And hooking it up to plain old chargers. But I've mistreated my lead acid batteries the same and they last 3 years or more. There's no Lithium ion motorcycle battery you can treat like a lead acid battery. I'm wondering if this is because they've left something out? I've opened up a couple of these Lithium ion batteries. I see a BMS in there. I know the BMS balances the cells by discharging cells that have higher voltages until they all match. But do most BMS have the ability to cut off the batteries to prevent over-discharging?
My second question is regarding charging. The most recommended Lithium ion battery for motorcycles is Shorai. They require a special charger, a balance charger I'm sure as it has multiple wires, not just positive and negative. Is there a BMS that will also balance the charging so you can simply hook up a standard charger to the + and - posts and know it's being balance charged? And isn't this important anyway because the alternator charges the battery this way and it's not made to balance charge?
Attached is a pic of the BMS in one of the batteries. Do you agree the only function of this BMS is to discharge balance the cells and it has not over-discharge protection and no ability to balance charging?
