Request 5S 3,000-5,000 mAh batteries
  • Request 5S 3,000-5,000 mAh batteries
    I've found that 5S batteries improve my FMS P-51D performance considerably. Do you plan to stock these?
    Thanks!
    Re: Request 5S 3,000-5,000 mAh batteries
    Have you checked amp draw with the five cells?
      Most planes operate on 3s, 4s, or 6s.
      Be careful running 5s on the P51, on a full battery and with full throttle you will be pulling very close to 65A (depending on air environment). A 70A or 80A ESC would be a better fit for 5s. But I've heard of many people using 5s with the stock ESC with no problem. But just be careful.
      Hangar: 90mm F16, 90mm F-15, 80mm Mirage, 90mm F-18, 1400mm P-40, 64mm F-22
      RIP: 80mm F-14
        We do have a 5S 4000 on the way. However, I would caution you about using 5S in an FMS plane. FMS recommends against this because there have been problems. Please know you ideally should upgrade the ESC to do this and quite possibly the motor if you are doing a lot of sustained WOT.
