LED Light Strips
  • LED Light Strips
    Can someone off suggestions on adding LED light strips to a plane? Never done anything like this before but interested in doing it to have something available for a night fly. Everything I'm seeing on Motion seems to be landing or nav lights. Any thoughts or suggestions would be appreciated.
    Bellke great modification idea. Most LED light strips you can get online are 12v, so a 3S battery will power those fine. If I were doing this, I'd just strip back the connectors, add lengths of +/- wiring between the strips to wherever you're mounting the light strips. I figure hot glue or CA would hold the strips on your airframe. If you don't want to add a 3S battery pack, you can use your flight pack by tapping into the the positive connector on the cell 3 counting in from the main positive connector lead to the ESC. Make sense? good luck, post pictures. Best LB
    Captain: Got any ideas?
    F/O: Actually not.
