I'm looking for an extension cable that I can use with the LED lights and blue box with Flightline planes. It's a two pin connector. I haven't had any luck finding these, I prefer one that's already assembled.
LED light cable extention
Originally posted by dkalwishky View PostI'm looking for an extension cable that I can use with the LED lights and blue box with Flightline planes. It's a two pin connector. I haven't had any luck finding these, I prefer one that's already assembled.
http://www.hansenhobbies.com/product...ors/jstbec_fh/
Take a look here and see if they have what you're looking for:
http://www.rc-connectors.com/index.p...geu9300ugde0m2
If you can't find what you need let me know and maybe I can make one for you.
Gotcha. I take it you only want the single beacon on the fuselage to "strobe" ?
I was going to add the tail position light on my Spits as well so when they get here tomorrow I'll know exactly what is needed. I have JST connectors but if they don't work I can order some extra connectors and make up what is needed.
If you're in a hurry one thing you could do it just take a regular servo extension, take your razor blade and just slice the connector down to two. Just make you sure you slice both ends to have the same wires.
Originally posted by Beeg View PostIf you're in a hurry one thing you could do it just take a regular servo extension, take your razor blade and just slice the connector down to two. Just make you sure you slice both ends to have the same wires.
A good sharp pair of mini-wire cutters gets the job done very well also.
I always cut the yellow/white signal wire side off so that the black/brown(negative - ) and red(positive + ) remains as a correct voltage color coding.Warbird Charlie
HSD Skyraider FlightLine OV-10, Sea Fury FMS 1400: P-40B, P-51, F4U, F6F, T-28, P-40E, Pitts, 1700 F4U & F7F, FOX glider Freewing A-6,T-33, P-51 VQ P-39 Dynam ME-262, FW-190, Waco ASM A-26; ESM F7F-3 LX PBJ-1 EFL CZ T-28, C-150
- 1 like
I finally found the connectors! I ordered mess of them so if trimming a standard servo connector doesn't work I can make one up for you. They're called JWT 2-pin
https://hobbyking.com/en_us/jwt-conn...-5set-bag.html
- 1 like
Nice job finding them Beeg:Cool:............gotta get me a bunch ;)
OH BITE ME.........figures that they're only avail global and not US warehouseWarbird Charlie
Originally posted by dkalwishky View PostIt looks just like a servo extension except it's two wires instead of three.
