just purchased the DX6,trying to figure out why I go from throttle cut to arm my prop automatically starts up without any movement from the throttle stick. Watched numerous vids on setup step by step but cant seem to get it right.Tried having throttle cut off on before connecting battery still didn't work. Any suggestions?....... thanks
Throttle cut on DX6
Sounds like your throttle trim is set to low idle when the stick is all the way down. I actually have all my electrics set so low idle (motor on) once I switch the throttle cut to the "on" position. This is about 10% power, but varies with the ESC and motor. Make sure your throttle trim is where you want it.
