Got a little problem. I've found out that if i put ANYTHING in aux 1,that the auto recovery mode will not work. I either lose landing gear,or flaps. I don't want to give up my flaps,which I've got set up on sb,the only 3 position switch.
I'm using sc for normal and auto recovery and sd for d/r.
Short of buying an 8ch tx,does anyone have a solution?
The SR86A is set up so that aux 1 is f/c channel,so,if i put flaps or gear in it,all that works in the gyro is "normal".
Help. Any way to mix anything?
