Thinking of going with lemon/admiral reciever moving from spektrum
  • #21
    Excellent!
    • #22
      Originally posted by gbugari View Post
      I'm sorry I did not explained well on my first post. The AILERON has Y connection and it uses one servo. On the other hand... The rudder has its own servo, so is the elevator. Total servos: 3 .
      Sounds from your description that you don't have a V-Tale. V-tale is actually shaped like a v, and both servos work together for elevator, and work opposite of each other for rudder input. Sounds like you just have a regular "cross-shaped" tale.??
      • #23
        Originally posted by Cactus Bobby View Post
        OK, thanks for the heads up. I do have the gyro assigned to switch G. Just for giggles instead of plus 5 I went to - 5 In Mix. To my amazement, everything works On mode C. I guess this tells me That my End points are backwards. Sound right to you
        What the Admiral RX600SP Rx needs to see for gyro control is, when channel 5 is at 100%, gyro is OFF, when channel 5 is at 95%, gyro is ON. This is the key info I needed to set up my mix on a JR radio which has completely different mix setups. Hope this clears up any confusion.
        • #24
          Hehe! His post was about a year ago. He's either long since figured it out or he's trashed it.
          • #25
            Yep and the last time on this forum was 11 months ago
