Admiral receiver stabilization & ailerons
  • Admiral receiver stabilization & ailerons
    I have an airplane I want to use the Admiral 6 channel receiver on. There are two aileron servos (one per wing). I noticed that with the second aileron plugged into Aux 1, the stabilization is only on one aileron (the one plugged into the aileron channel). Is there a way to send stabilization over to Aux. 1 as well? I'm guessing that doing a mix in the transmitter (dx9) won't work.
    Hi, Spelunker. Welcome to Hobby Squawk.
    There is no stability control on Aux 1 with this rx. Only the standard three channels for ailerons, elevator, and rudder are stabilized. You'll need to connect both ailerons to the rx with a y-harness.
      Thanks. I figured as much. I guess I was just hoping! I've been doing this hobby for some time, so thankfully I have some Y-connectors laying around!
