Beeg, you're the best! I printed it and saved the .pdf in case space aliens beam down to steal it. Have one more question: since this receiver will go in a gasoline powered J-3 Cub, where on the receiver does my 6V NiCad battery plug in? Only ports open are "Gear", "Bind" and "Aux". I am using a six channel DS6 Spectrum transmitter. I know how to re-assign channels, but will wait to hear from you.
ADMIRAL RECEIVERS & SATELLITES
OV10, thanks for the reminder. Again, thanks to all for your fast assistance. I plan to install and bind my Admiral receiver tomorrow morning. Too hot in my garage now (105F)
Since we are talking about receivers, the first receiver I tried to install was a Spektrum AR410. It seemed to bind OK. This was my connection scheme:
BATT = My NiCad battery
1/DATA = Throttle servo
2 = Aileron servo
3 = Elevator servo
4 = Rudder servo
I'm sure I followed correct protocol for polarity; negative oriented toward the bottom of the receiver. The receiver orange light was on steady. When I pushed the switch on the side of the aircraft to "on" servos bumped then receiver light went out. I'll recheck everything tomorrow.
Beeg, OV10,
Life is good. My Admiral receiver is installed and functioning properly with all servos. One of my problems was I did not have the receiver mounted flat (instructions say to do that, but …) and the antennas were not 90 degrees apart.
My other problem was my power supply. I had a five battery module of NiMH batteries, but they would not hold a charge (too old?) so I replaced them with a new Lithium Ion battery pack.
I just invented a new axiom: When all else fails follow instructions.
I really do appreciate the information you both gave me. My next tasks are to break-in my new engine and attach the wing struts. My hope is this aircraft will be docile in flight and easy to control.
Originally posted by Spurr View PostNeed some help. I have an Admiral DSMP six-channel receiver. Brand new. Now I want to install it in a 65" wingspan J-3 Cub. Engine will be gasoline. MY QUESTION: Where can I find a online manual or quick start guide? I contacted Motion RC and they just said they don't sell 'em any more.
