Hey - some of you may have seen my posts on the Phantom F4 forum.
Long story short I had a fade/signal loss /interference and nose dived into the ground (wooooo)...I was so angry ....I'd flown it for a grand total of 17 seconds. Anyway...she's just repaired now, and looks great.
So you get the full picture, KIT USED:
- Spektrum DX6
- AR636 (under battery tray BUT aerial running away from batter direction UP)
- satellite RX (in the nose with aerial in different plane and direction to main antenna)
- Phantom F4 90mm
- Zippy 6200mah 40C battereis
- RC Geeks Afterburner
- Ferrite rings on stock esc to cut down on interference
(I only added the satellite and ferrite rings after the crash)...
However...to confirm my suspicions of crash due to a fade I went to check out the kit at the field with some ground testing today. To range test with spectrum I went into the range test mode and it gave me reduced power, i measured 30m and had a made change the orientation of the plane. It was fine in most orientations but did glitch out sometimes, in a tail or nose orientation more, but it was consistent.
My questions;
- During a spektrum range test, at 30m....should the RX be faultless? Or is it normal to get a couple glitches / brown outs as its operating on reduced power?
- I had a thought of piercing the fuselage and putting the aerial out of the bottom (and satellite out the top) pointing in 90 degree opposite directions...is this silly? Seems like a good idea to really get some distance between the electrics and the aerials.
- what else can I do if the range test isn't satisfactory?
I could go to my mates full scale runway and range test (not in range check mode) and drive it 900m away and check it like that!!!! (he flies an RV6, I fly a eurostar)
Anyway ....
Any help is HUGELY appreciated - I won't fly it until im confident of no brown outs...i can't afford another!
Ben
- Spektrum DX6
- Phantom F4 90mm
My questions;
Anyway ....
Ben
