Three weeks ago I purchased a Spektrum NX6 transmitter, charged it up , set it up no problem. Went to charge it to go fly & when I plugged it in the Spektrum logo flashes on the screen, but the charge light doesn’t come on, left it plugged in for several hours, determined it wasn’t charging. Called Spektrum (Horizon) was told to send it in. They sent me a new transmitter. The second one is doing the exact same thing! Charged fine the first time, now won’t charge. Anyone had or heard of this issue. It’s Sunday so can’t call until tomorrow. Hard to believe the exact same thing is happening. Frustrating!
Spektrum NX6 Charging issue
I just had the same thing happen on a brand new 2 day old NX6. Saw your post, Then decided to take and unplug the transmitter battery in the battery compartment, I plugged it back in and now it’s charging. The light is back on, I have no idea if that connection was loose and causing that problem but I would be interested to know what you found out from Horizon Hobby about this situation, I don’t know if this will last on mine or not, please keep me posted of what you figure out in case my self or others run into the same situation, thank you
Well, it seemed fine, but did it again. Unplugged battery, plugged back in and it worked again. Now last night put on charge, and green light came on, but it didn’t charge. Then it starts working again after I unplugged charge cord and then it worked. Looks like it is a spurattic type problem. Back to Hobby Shop it goes tomorrow.
This is literally my first time on this forum, but I am glad I found it. I got my NX6 today and I fell in love with it when I first saw. Then there was the charging issue. I have something to admit, I do actually work at Horizon....but I didn't want to bother my coworkers with something I could find on my own. Luckily I found this lovely forum. Unplugging the battery and plugging it back in worked perfectly for me, and I will see if its a permanent fix. I see now that this is an issue among other pilots as well and I feel like this is something that should be fixed. I am still a fresh employee at the company, but I may be able to reach out to someone and point out some of the issues other people are having as well. Maybe Spektrum will release an updated version. Thanks for your help! You guys are awesome!
After returning the first one for this issue I am having the same problem with the second one only difference is the first started having the issue the first day and the second one 2 weeks after. I am ready to take it back. Nothing like wanting to go out in the morning just to find your radio didn’t charge again. Unplugging the battery and plugging back in seems to be a short term fix. I also called and talk to horizon and they told me they never heard of the problem before me. I hope this gets resolved soon.
So I recently called again on the issue and this time I was told it wasn’t a software issue which means a software update won’t fix it and the fix is to unplug the battery and then plug it back in. Well I have done that several times and while it works for a charge or 2 I didn’t spend the money I spent to have a radio I have to babysit just to make sure it charges. But I was offered to warranty it replacing it with a new NX6. Unfortunately I don’t so the point in exchanging it for the same radio just to have the same problem. I am on my second one with the same problem. So am just supposed to hope the third one is a charm. I am hoping to just straight up return it which is unfortunate because battery issue aside I really like the radio. Anyone else get anywhere regarding the battery issue?
