Rx takes multiple tries to connect
  • Rx takes multiple tries to connect
    I did have a bit of a rough landing but I'm concerned about the Rx. The Rx synced with the radio every time flawlessly before but now I may need to plug the battery in several times or turn the radio off and back on to get them to connect. Any idea as to why? Jr 12x and a spectrum Rx.
    Sounds risky. First thing is to check all electrical plugs and wires to make sure one of them isnt loose. Then you may want to send it in to have it checked out. One to to isolate if it is the Receiver is to install a different one and see if you get the same error.
      Click the link for the appropriate fix
      Electric RC Jets - Rx not always connecting - I'm flying a Freewing T45 and I had a bit of a bouncy landing. Ok, it sucked. Anyway, no real damage but now when I plug the battery in , sometimes it syncs with the Tx, sometimes it doesn't. In order to make it work, I have to unplug and plug the battery in 3 or 4 times.
