Help with Sound card setting FW P51
  • Help with Sound card setting FW P51
    Can someone tell me where the small switch is on the sound board on the P51 I need to re-set at low and high throttle. I would really appreciate it much.
    Re: Help with Sound card setting FW P51
    The small microswitch is on the end of the green sound card. Here is a snippet from a user on RC Groups who found a simple and easy way to calibrate the sound system:
    ****** start ********
    Remove the prop to start with!
    First calibrate the esc before calibration of the module. (trim on neutral)
    There is a micro dip switch on the module. It needs to be pressed (keep it pressed) once with lowered throttle until it beeps and once at full throttle also with a couple of beeps.
    If the blue led is off press it once to turn the module back on again.
    Note: the battery for the sound module needs to be connected at all time as well as the power for the plane.
    Then final adjustments can be made with the trim.
    Quito
    ****** end *********
    Hope this helps,
    Mark
