Official Black Horse Edge 540 V3 2000mm ARF Discussion Thread
  • Official Black Horse Edge 540 V3 2000mm ARF Discussion Thread
    Product page: https://www.motionrc.com/products/bl...-v3-2000mm-arf
    The Zivko Edge 540 manufactured by Zivko Aeronautics is a highly aerobatic aircraft. Capable of a 420 degree per second roll rate and a 3,700 foot per minute climb rate, it has been flown to victory on the international Unlimited aerobatics circuit several times since the mid-1990s. A tandem-seat version is sold as the Edge 540T.
    The Zivko Edge 540 is the most common aircraft used in the Red Bull Air Race World Series.
    Our model is scaled to approximately 1:3.7 and attention has been given to providing a realistic appearance with outstanding flight characteristics. The model was designed for electric power but can also be flown using a matched pair of internal combustion engines of about 30-35cc displacement.
    • Lightweight, strong, and fully sheeted laser cut balsa and plywood construction
    • Covered in high quality Oracover
    • Recessed hinges on all control surfaces
    • Large easy access fuel tank/battery/servo access hatches with sprung loaded latches
    • Painted and detailed cockpit, pilot and interior included
    • Fiberglass twinned control horns with ball link connector
    • Pull-Pull control system on the rudder for precision control and authority
    • Two-piece, plug-in wings simplify transportation and assembly.
    • Fiberglass cowl and landing gear covers/pants
    • Fully illustrated instruction manual included and also available for download (see tab above)
    • Black Horse Edge 540 V3 2000mm (78.74") Wingspan - ARF
    Requires (Electric):Requires (Gas):
    • Engine: 30 - 35cc 2-stroke, NGH GT35R recommended or 38-42cc 4-stroke, NGH GT38 recommended
    • Gas Propeller: 18x10-20x8
    Click image for larger version  Name:	edge updated.jpg Views:	1 Size:	73.0 KB ID:	194497
