Using Z-POXY on my new SU-35
  • Using Z-POXY on my new SU-35
    The SU-35 comes excellently packaged from MotionRC.
    I used the epoxy called Z-Poxy, which takes 20 to 30 minutes to cure, coating my entire Freewing SU-35 with a brush, an additional coat added between intervals. The Z-POXY has a tendency to run unless it's on a level surface so be warned. The results came out pretty good and the jet flies very well. The coating protects the fragile EPS foam surface against scratches and nicks.
    http://www.youtube.com/watch?v=aZQ6l0rCg-U
    Sound module from MrRcSound.com
    http://www.youtube.com/watch?v=YmMDaN41l04
