The Collings Foundation operates one of the world's greatest collections of historic aircraft.
Landing gear tires change
  • Landing gear tires change
    Good evening friends,
    I want know please if someone already saw this type of landing gears and how can i change the tires (or al the wheel) on it.
    The rubber (or EVA) is already very used as you guys can see on the images...honestly i do not have any idea how to change the wheels (45mm)...i can't see any visibale screw, just some pin as the axle.
    Below is the link wich seems the same model.
    https://hobbyking.com/en_us/turnigy-...-and-l-59.html
    Thank you all! Safe flights!
    Hello Raphael,
    Your picture #1 shows the bottom of the strut with a hole that looks to be threaded and most likely has a set screw up in there locking the axle pin into the strut.
    Those set screws usually are turned with a 2.5mm allen(hexagonal) wrench.
    ScaleTech OV-10 Bronco; HSD A1 Skyraider; FlightLine: F7F-2D, P-38 Allied Green, Sea Fury; FMS 1400: P-40B, P-51 Marie, F4U Olathe, F6F, T-28, P-40E, 1500 Razor, 1700 F4U and a Fox glider; Freewing: A-10 Artic Thunder(100+ parts to rise again), A-6, P-51 Iron Ass; VQ: P-39, JU-52; LX PBJ-1(B-25), P-40E; Dynam: ME-262, FW-190, Waco, Catalina; Phoenix Spitfire; Maxford Antonov AN-2; Starmax L-4 Grasshopper; Eflite 1100 T-28 float; Tech1 P40; NP O-2 Skymaster; ASM A-26 Invader
      Originally posted by OV10 View Post
      Hello Raphael,
      OV10,
      Yes, it makes sence...seems to have something inside...youre right.
      For the nose wheel is a little bit different, i didnt saw this hole in the strut..ill try to take a picture and post.
      I apreciate your attention replying my post.
      Thanks and safe flights!
      By the way, i have some twins in my hangar (props) and agree they are 2x more fun :-)
        I replaced the wheels on my Dynam C-47 with slightly larger low bounce wheels. It took some doing. I drilled out the plastic axle to remove the wheel. Then I put in an aluminum tube and a brass axle. Works great. Doc
          Thanks Doc.
          I think your C47 dont use the same landing gear than my jet..in my case (as per above images) the axle is aluminum (seems) so ill need to figure out how to do it.
          The wing LGs seems to have a screw as OV10 mentioned but for the nose wheel is a different history....."Chinese design as usual"
          Keep you gusy posted.
          Safe flights!
            Thank you all that helped me on the landing gears change!
            As per our buddy OV10 said, the screws was there !
