Official Skynetic 1600mm Air Titan Thread
  • Official Skynetic 1600mm Air Titan Thread
    Product page: https://www.motionrc.com/products/sk...tan-1600mm-pnp
    Air Titan 1600mm (63") Wingspan - PNP from Skynetic - SKY1031-001
    The Skynetic Air Titan is one of our most versatile and fun to fly RC airplanes. Its large wingspan, high-wing configuration, and durable metal landing gear make it an ideal trainer aircraft for beginner pilots. But this is not just a great trainer, the Air Titan's powerful motor and solid construction mean it can handle advanced aerobatics and more aggressive flying techniques. You can even use the Air Titan to tow your favorite glider to high altitudes using the included servo-controlled tow hook. Multiple landing equipment options is another reason why the Air Titan is one of our most popular aircraft.
    The kit includes large wheels perfect for grass or pavement. If you want to fly off of water, there is an optional float set available with working rudders so you can easily takeoff and land on any pond or lake. And the fun doesn't need to stop in the Winter since Skynetic also has an Air Titan snow ski set available. The main wing can also be removed to make it easier to transport the Air Titan. Made of light yet durable EPO foam with a high wing and rugged tri-gear, the Air Titan is tailor-made for anyone wanting a large-size trainer with the versatility to fly on pavement, grass, water or snow.
    New Livery
    The Skynetic Air Titan comes with a new attractive blue and white livery.
    Easy To Transport
    The Skynetic Air Titan is easy to transport to and from the flying field.
    Includes Functional Flaps
    The Air Titan comes with functional flaps for shorter takeoffs and slower landings.
    Takes up to a 4S 4000mAh LiPo Battery
    The Air Titan can take up to a 4S 4000mAh LiPo battery for long flight times.
    Functional Tow Hook
    The Skynetic Air Titan comes with a functional tow hook for towing a buddy's sailplane up to altitude for maximized excitement and fun!
    Includes New Admiral ESC
    The Skynetic Air Titan includes a new Admiral 50 amp ESC for reliability.
    FEATURES:
    • Durable EPO and high wing with large camber to increase trainer capabilities
    • Rugged and strong tri-gear for added insurance on takeoffs and landings
    • Multiple landing equipment option allow you to take-off from pavement, grass, water or snow.
    • Servo controlled tow hook allows you to tow your favorite glider with ease
    • Snow takeoffs and landings available with snow ski set (not included see spare parts)
    • Water takeoffs and landings available with float set (not included see spare parts)
    • Flaps added for quicker takeoffs and slower landings
    • Easy to remove wing and tail section makes transport a breeze
    INCLUDES:
    • Skynetic Air Titan 1600mm (63") Wingspan - PNP
    REQUIRES:PRODUCT SPECIFICATIONS:
    AGE LEVEL : 10 AND UP
    SKILL LEVEL : BEGINNER
    BUILD TIME : 1 HOUR
    Wingspan 63in / 1600mm
    Length 50.7in / 1287mm
    Flying Weight 2450g
    CG (Center of Gravity) 85-95mm from the leading edge of the wing at the root
    Power System AS3520 KV680 Brushless motor (installed)
    Electronic Speed Control 50 amp brushless ESC with XT60 connector (installed)
    Propeller / EDF Electric propeller
    Servos 2x 9g, 5x 17g
    Landing Gear Tail Dragger
    Required Battery 4 Cell 14.8V 2600 - 4000 mAh Li-Po battery with XT60 connector (required)
    Required Radio 5+ channel full range radio system (required)
    Ailerons Yes
    Elevator Yes
    Rudder Yes
    Flaps Yes
    Lights No
    Hinge Type Foam
    Material EPO Foam
    Skill Level Beginner
    Build Time 1 Hour
    Recommended Environment Outdoor
    All of the Skynetic stuff I have seen so far is awesome!
      Looks great. It’s a heavier beginner plane, but this is needed in stronger wind gusts.
      For comparison are the Eflite Turbo Timber and Avios Grand Tundra.
      Eflite’s planes always include AS3X SAFE, which I don’t like. It’s better to configure your own gyro, and there exists better than AS3X SAFE.
      You probably also easily fly it without gyro.
      The Avios Grand Tundra offers 6S and 4S. That’s for me the best challenge. But I guess that the Skynetic Air Titan has a higher quality and durability. This will show us the future.
      Most important is that this plane performs well in bad weather, which we always have here.
        Will this aircraft fly on a 3s lipo?
