Flying wing
  • Flying wing
    I'm designing a BOT style flying wing. NO vertical stabs. If she flies as well as she looks... what a beauty! Doc
    The easiest way to avoid needing veritcal stab is to provide ample sweep-back. This acts somewhat like dihedral and vertical stabilizer.
    Then you'll want some form of controlled drag at the wingtips for yaw control.
      I'm using sweep as well as dihedral just like the Horton gliders. An airfoil with a slight upward turned trailing edge (reflex) and elevons on the outer part of the wing only, are important for stability. Also washout can be difficult (if not impossible) on a folded foamboard wing, so extra reflex on the outer 3" of the elevons will help reduce tip stall tendencies and take the place of washout. I hope all this research pays off! Doc
        That's why I'm waiting til I get a 3d printer to continue my design. Gonna print the ribs out
          Let us know how that works out. I just finished my BOT flying wing airframe. (About $4 in materials) Now for the expensive part, electrics. It's 2 meters. If this flies I'm going to build a 3 meter wing, either BOT style or HO IV. Doc
            Nice I think it should do well. Just setting the battery always was the PITA part. To get that critical cg point exact. Uuuugh.
              Yeah, battery placement in the wings I've built is a problem. CG is really sensitive in these things! Doc
                Yes, that's why I'm looking to the 3d printer route, I'm hoping to have a solid solution for the battery placement that I can first move around, then epoxy in when I find the perfect place. I think that will be my best chance of getting this right this time.
                  doctormike, Don't know if you've flown your wing yet but I got back from the Horizon Hobby Aerotow two weeks and a guy built and flew this beautiful wing on it's maiden flight that flew very well.
                  video https://www.flickr.com/photos/422200...7698096661605/
