    as to why you're even considering this while at the same time requesting recommendations for a trainer 64mm EDF over on the 105 thread
    I just want to know what would be best and kinda compile a list of things I can fly on my field.
    I know its dumb but I get obsessive over things like this.
    • I'd be careful with 230' and some of these larger scale jets. Takeoff should be fine with just about any of them with the exception of the F14; however, landing may be a different story. Granted you can get just about any of these planes to stop dead in about 100' or less, but when learning how to drop a plane in at appropriate landing speeds you can overshoot a ton of runway very quickly. Take it from me and beat on some easy, more friendly jets for a while first (like the 70mm Rebel). I'm not saying landing in less than 230' isn't possible, but you could easily put this plane in the grass. I'm still relatively new to the hobby at 1.5yrs and even though I've gotten quite comfortable with my current jets (A10, A4, F15, F22) I wouldn't even attempt at bringing them into a 230' strip.
      • Originally posted by Grady.c View Post
        I finally decided I need this plane, but I don't know if it'll work on my runway. I have around 230ft of softball field with fences on each side of the strip. If you think I can get this gorgeous plane off the ground and to a stop let me know, please.
        It would depend a lot on your fields altitude, seeing that your in Co. I'm at 4700+ and the 8s takes a bit to get airborne and even more of "a bit" to get stopped. I would say roughly 300ft to take-off and upwards of 400 to 500 to get stopped after a hot landing. I am sure that with a high A you could land it pretty short though but I've only got maybe 6 or 8 flights on mine so far. I'm sure it will take-off in less as well but I like to build up some cushion since i'm lucky enough to have an 800ft runway. Personally, I think 230ft with obstacles on each end is too risky for this heavy of a plane on 8S but that's just me. Having never flown or seen a 6S fly I can't really comment on that.
        Hope this helps!
        • Great Jet. Flies very well. I prefer a lot of room whenever I fly this one. Keeps all the pieces together that way !! Cheers !!
          • Attached Files
            • Originally posted by Bobaroo View Post
              Spectacular work!
              Current Hanger: Flight line 1600mm Spit ( Clipped ) FMS 1400mm 109, Durafly 109, Eflite P-47, Eflite PT-17, UMX Pitts, UMX Timber, Twisted Hobby Extra, Extreme Flight EDGE, FREEWING, A-4, Avanti, A-10 , F4. Byron T-6, Top Flite P-47, H9 Corsair, Ziroli Hellcat. Jeti DS16 Carbon /Spektrum DX8, Freewing F-14
              Just arrived: Freewing F-22,On the way: Flightline F4U Corsair
                CC, The stl files for a 600 Gallon version are available on Thingiverse, designed by DirtyDee, if you have access to a 3DP. Check if that is the one you want. I will be adding that tank to my Phantom when I get to that part of the build. I could print one for you as well then and ship it to you. Let me know. Best, LB
                I’m interested in one of those center tanks as well. How do I buy one?
                • Hey y'all, does anyone know what's up with JHH, are they closed for vacation? Ordered 2 pilots for the Phantom on Dec 14th, 2018 and still no replacement recruits. Best, LB
                  Captain: Got any ideas?
                  F/O: Actually not.
                    LB,
                    What size did you order? 1/12?
                    • Originally posted by PhantomNut View Post
                      LB,
                      Yes for the FW F-4. Why? Out of Stock? Out of Production? Outta Luck? Outta questions...Best, LB
                      F/O: Actually not.
                      • Hey Y'all, Empennage painting, shading, and assembly continues slowly, though getting there. Best, LB
ID:	172244Click image for larger version
                        F/O: Actually not.
                          I'd like to get some for my F-4 if they ever decide to ship them.
                          • Originally posted by Quickstop View Post
                            The real f-4 could carry 16,000 pounds on the wings and internal fuel was 8000 pounds, so yes, I'd say the real one had slightly higher wing loading. Really not comparable in any way except looks
                            Empty weight of the F-4S, 34,000#. Could carry 7000# fuel internal, 4000# in the wings (which was the only place we could dump from) and 6000# in the Centerline. That makes 51K. Our max Cat was like 54K. Sidewinders were 250# apiece. We usually carried a couple. Sparrows 500#. Often had none. Meaning if we wanted to bomb we could only carry 4 Mk82 500# bombs.
                            Max trap fuel was 5.1. So the wings and centerline had to be empty, and the "main bag" (actually it was like 7 fuel cells down the turtle back) could only have 5100#. Enough for 3 looks daytime. 2 at night. Then off to the tanker hanging right overhead. Or bingo.
                            • MotionRC has been out of the Ghost Gray for a while, but Freewing says they can sell to me direct. A rep named "Mike" is asking me to wire transfer money to China. On his recommendation I tried "Xoom," but Xoom dissaproved the address and bank account info he gave me. He then suggested an international wire transfer. My bank charges $40 for that, and he said he'd take $40 off the price.
                              Anyone have experience with Freewing? Buying direct?
                              • Originally posted by curlyculp View Post
                                It's a scammer and has been covered many times here.
                                  DO NOT SEND MONEY! SCAM.
                                      Thanks all for the warnings on the Scam. Glad I checked. Seemed a bit fishy. I've bought direct from FMS and it was a much more "normal" buying experience.
                                        Is the whole freewing-model.com site a scam too? The "Mike" guy that's trying to get me to wire money is the same email address as listed on the site.
                                        • Love your avatar..... Just too cool!!! :-) As far as I know, that entire site is BS... It sure looks legit.
