XK Edge 430 RTF With Gyro
Official Freewing 90mm F-16 Falcon Thread
  • just ordered the 8s power upgrade for a new F16 90mm, Is there enough room under the canopy for 2 4s batteries to power it and still balance ok for it? If anyone can help with this question I would very much appreciate the info. Thanks, Kevin
    • My buddy runs his on 8s, I will ask him about what he had to do to get the batteries to fit, I know it's a tight fit, CG is fine if you can get them jammed to the back as much as possible. I did the maiden on it and I had his CG set about 110-112mm which is where I run mine at on 6S. I can tell you this much, he said it wasn't worth it, he wishes he would have kept it on 6s, didn't gain much, maybe a little more thrust is all, but the weight is more, of course he is running brakes and another small lipo plus the two large 4S lipos. I do all of his test flights right now until he gets more jet time and figures out how to land it. I feel the difference in power but it's not a huge difference to me. He was able to get the two 4S batteries side by side in there though and still adjust the CG.
      • Originally posted by kscobey10 View Post
        According to Motion RC they should fit just fine. But as mentioned above it may not get you much more than you already have. The plane is going to gain weight and this plane doesn't care much for higher weight.
        I am planning on getting an ARF plus here pretty soon and will be dropping in my 4082 1600kv inrunner set up. It worked great on my F-15 and since the F-16 is a cleaner air frame I am thinking it will do even better.
        I have way too many planes to list off... But I love to fly them all! the 80-90mm Jets are my newest addiction! Also check out my youtube channel for TONS of flying footage. https://www.youtube.com/user/gooniac33
        • Guys,
          I'm new to this forum and I have a query. Tried to remove my f16 wheels for brake conversion. Got grub screws out OK but the wheels are stuck tight Possibly loctiite in axle? Any help would be appreciated
          • In everyone's humble opinion, are the Flaperons necessary or helpful on this ship?
            • Originally posted by gooniac33 View Post
              Gooniac did you ever do the inrunner on the F-16? I am also considering that same thing.
              • Originally posted by seaviper View Post
                It is on my list. Haven't done it yet but will be in the coming months. I am actually considering putting the new fms 90mm fan in the T-45 and possible the F-16 as well. High KV motors but they have really good half throttle performance as well. The new Scorpion was clocked in excess of 130mph.... but still getting about 4 mins flight time and not hard on batteries... I am gonna get a lot of planes here over the next few months...
                  I do not recommend using the stock ESC with the FMS 1900kv motor...it will eventually burn up the ESC. It happened to me and several others...read the related posts on the RCG FW F-16 thread.
                  Sean
                  • Originally posted by EDFjetpilot View Post
                    Sean
                    Don't worry.... I am a big fan of the Red Brick and plan on getting one of those....
                    • My F-16 went out this morning for a couple of flights and had a photo shoot with the A-4.............
                      • Nice Shots!
                        • This jet is very impressive! I have seen my buddy's fly many times and this video is one of those flights.
                          • Originally posted by GBLynden View Post
                            WOW!! Great flight and landing! I kinda want the bigger F-16 too... the details are what I like the most!! no room though!!!
                            • I am short on room in my car or I might have one too!
                              • Does anyone run flaperons with a gyro on This? If so how did you do it because I couldn't seem to figure out how to set it .
                                • FREEWING F16 falcon VECTORED JET AILERON AND ELEVATOR SETTINGS THE FREE WING VECTORED JET AILERON AND ELEVATOR SETTINGS,
                                  I down loaded the manual and it does not give you the min and max settings for the ailerons and elevator . can any one help me with this and how much exponential on the low rate and high rate should I add to it?
                                  here is link for manual pdf https://cdn.shopify.com/s/files/1/10..._Manual-EN.pdf
                                  • Anyone have a program for the F-16 compatible with the DX9 that can be emailed?
                                    • Just finished mine. Ready for Maiden. JP Hobby brakes, Runcam Eagle 2 pro, and Foxeer 600mw vtx installed.
                                      • So, I notice the 90mm Super Scale F-16 is no longer listed in the Jets section or the spare parts section on Motion RC. Anybody know what's going on? Have they discontinued it, and are there no more parts available?
                                        • same thing with the 104....
