  • Originally posted by A.B. Jones View Post
    If you hear a loud scream and an explosion for New Mexico, I fixed it!.
    AB, Welcome to Hobby Squawk. Post pictures when you can. Best, LB
    • My Phantom F-4 is ready for the maiden flight. Maybe you saw it already on Facebook. In early September we have a Jet meeting at our flying field.
      Last modification was to add a central afterburner.
ID:	210131Click image for larger version
      • Gorgeous Wobisch! Man there are a lot of beautiful repaints in here! Well done all!
        • Originally posted by Wobisch View Post
          Woe-B, Absolutely Phenomenal Phantom, Sir. I wish you severe clear and safe landings for your 1st Check Flight.Best, LB
            Wow, that is very nice, wish you lived near me, I would like to buy that, another stunning F-4.
              Beautiful! Go Marines!
              • I can get behind that ! :-) AWESOME Livery! And AWESOME JOB!
                • Thank you all for your nice comments. Love it, my beauty.
                  My Phantom looks also nice from underneath. But nobody will see that.
                  • ..and a closer view of the details and nomenclature. Took me a while to apply that.
                    Click image for larger version  Name:	Bildschirmfoto 2019-08-14 um 12.02.58.png Views:	0 Size:	1.49 MB ID:	210188
                      Woe-B, Where did you find your amazingly detailed Nomenclature? Did you print those? Looks great, I must know your secret... Best, LB
                      • I printed tons of waterslide myself. Not only the nomenclature, but also the rivets. Hell of work.
                        Since I had no idea what kind of nomenclature is printed on the real thing, I created my own. I hope nobody will come so close that he could see what is really going on there. You all would laugh about it. But I live in a german speaking region. Nobody cares about my nomenclature. It's just about the look.
                        Have fun:
Name:	Bildschirmfoto 2019-08-14 um 16.49.29.png
Name:	Bildschirmfoto 2019-08-14 um 16.49.41.png
Name:	Bildschirmfoto 2019-08-14 um 16.49.34.png
                        • Woe-B, It simply looks great and at 75 MPH /10 Feet above the ground it will be Phabulous. Best, LB
                          ps: Laser Printer or InkJet? What type and manufacturer of decal paper?
                          • Wobisch….Excellent work....the F-4 looks fantastic! Also, thanks for sharing the waterslide decals.- TG
                              LaserPrinter paper is much easier. Does not need to be covered with a spray. I got the decal paper in the local Airbrush shop. I cannot tell you the brand, it is not labelled.
                              • Hi Everyone,
                                I just received my FW F4 and I am in the process of putting it together. I have a question, I have a Spectrum 8010T rx and am having trouble try to fit the servo plugs into the receiver. It appears the servo plugs are too big even though they look like the standard plugs you might find on most ARF's Are others encountering this problem or is it just a luck of the draw going on? I want to use this proven receiver rather than go with a new unit. The 8010T was used in a Flex Jet and worked perfectly. If it is uncommon I may have to contact
                                MRC to see what can be done.
                                Carlos G
                                • On some of my models I've had to grind the corners of the plug. This makes a tight fit into the receiver.
                                    Stunning Model!
                                    • Originally posted by Carlos G View Post
                                      Hi Everyone,
                                      Carlos G
                                      Welcome to Hobby Squawk! The connector fit into the 8010T and the other Sprektrum receivers is very tight, but they will fit. Using a fingernail emery board or just a sanding block, you can touch up the corners, but I usually just take my time and wiggle them in. I have 9 of those receivers in use... One other thing... if you use the telemetry, you will sometimes get a warning or reading that the receiver voltage is 2.5 v dc. This is not accurate! Even with a CC 20 amp Pro BEC, it will randomly give that reading... Freaked me out since I was flying the first time that happened!
                                      Hope this helps! Jerry
                                      • Hi Everyone,
                                        Thanks for the info regarding the servo plugs. This is my first FW model and so I had not expected to run into this hiccup. I will modify the connectors as needed. I have been in rc since the middle 70's and for the most part wire connectors have never been a problem. I have had many brands of radios and as long as you made sure that you used Kraft with Kraft, Futaba with Futaba, or Airtronics with Airtronics all was good. Now that standards are becoming somewhat unpredictable, I guess you cant take anything for granted any more. I hope MRC can work with their vendors to try and standardize the connectors .
                                        I did try some HiTech servo extensions and they fit the Spectrum rx so I guess all is not lost :) I have notice though that some connectors are no longer gold plated like they all use to be. So I have to sort through part numbers now to try and find decent connectors.
                                        Sorry, I will get off my soap box now.
                                        Carlos G
                                        • Hey guys, here's a cool before the sunrise flight from last weekend:
