Like most, I've had trouble with cg (tail heavy) on my PT-17. Biggest battery I can fit on the slide-in tray is a 3s 2600 30c 210g as far forward as possible. Added an ounce of sick-on lead weights on the interior foam shelves bordering the opening to the motor mount and manually adjusted clevis for some down elevator which helped, but not enough. Next step is weight in the cylinder cavities of the dummy radial, take out sliding tray and velcro in a 3s 3300 30 c 256g or 3s 3700 40c 282g battery etc although I dislike adding more weight. However I noticed in the parts listing for this plane on Horizon a Prop Adapter Hex 32mm (EFL8204) which appears to be heavier than stock set up since it has a metal spacer with screws as opposed to the stock plastic. Anybody familiar with this? If so, how much heavier is it and is it drop-in with stock shaft and prop or if not, what has to be done to install? If its only 15g heavier that might be enough since its so far forward.
PT-17 from eFlite
Go to Wal-Mart or somewhere you can get B-B`s. Start with one cylinder adding B-B's until your CG is good. It will take some time and don't try to short cut it. After you fill a cylinder slip it back on a the the prop adapter and prop. You can use whatever glue you want just test what ever you are using on the plastic.
Originally posted by Saltydawg View PostGo to Wal-Mart or somewhere you can get B-B`s. Start with one cylinder adding B-B's until your CG is good. It will take some time and don't try to short cut it. After you fill a cylinder slip it back on a the the prop adapter and prop. You can use whatever glue you want just test what ever you are using on the plastic.
see post #1 and #33.
Ouch, sorry to hear that. Don’t misinterpret not enough down elevator for tail heavy condition. I needed about 10 turns of down elevator adjustments to get it leveled in flight, but on the balance stand - it was just a shade nose heavy. Don’t just use your fingers - put it on a stand.
Originally posted by FreightShaker69 View PostIve read the cg in the manual is complete off. GG is supposed to be measured 86mm (3.38”) from leading edge of UPPER wing. What exactly is everyone using as their cg then? I bought this plane second hand, haven’t flown it yet, but according to the manual my cg is perfect.
