Yes. And it can be taken a step farther and go into a flat, zero speed fall if you let it get too slow. I tried doing flat spins and it ends up in this zero speed flat fall, even with ailerons and rudders...Cool when you do it high but deadly if you do it low. You also have to be careful getting out of it, full throttle and ailerons and it starts doing a wild wing rock until it gets some airspeed.
Another odd thing is doing a tail slide gets it all weird. Hard to describe but very cool, and again make sure you have height when you do it.
Don't slow this plane down with out the wings being level. Don't apply full flaps until level on final. Don't give it much if any rudder when slow. I've settled on a CG at about 95mm.
30 flights on mine and all is good.
Originally posted by Rcfiddy1
View Post
