Just finished up my VFA-81 Hornet.
Originally posted by Twister006 View PostJust finished up my VFA-81 Hornet.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
Originally posted by Twister006 View PostJust finished up my VFA-81 Hornet.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by Twister006 View PostJust finished up my VFA-81 Hornet.My YouTube RC videos:
Got the maiden plus 2 additional flights done on BA #2 today. Happy with the way it flies after replacing the stock elevator hybrid metal gear servos with FW 17g full metal servos (same as the F-22). No issues with pulling out of power dives for a high speed pass.
It was a Blue Angels kind of day, although I was not able to get the turbine in the air. Still need to work on the fuel lines, but I'm getting there.1 PhotoPat
Originally posted by Quax View PostJust wanted to install my RC Geek centerburner but turned out that one of the screws on the motor cone has been turned too hard - cannot remove it all :-(
Originally posted by Quax View PostJust wanted to install my RC Geek centerburner but turned out that one of the screws on the motor cone has been turned too hard - cannot remove it all :-(Pat
Originally posted by Dustman View PostRCjetdude, where did you get those drop tanks from? And Bobaroo where can I get the Full Cockpits and Complete Ejection Seats from
?? Twister006 did you print up your missiles and pylons yourself?
Originally posted by crxmanpat View PostThe grub screw may also have some Loctite applied to it at the factory. Take a soldering iron and heat it up to loosen the Loctite, then as Carl said above, try using a slightly larger Torx key, or take the regular Allen key and hold it at an angle. Should come out then.
