View Post
Hi Thisguy65, where the box is calling out for example "70mm" for the "Rudder pushrod length", the length of the metal pushrod in the picture itself is 70mm, but the total length once you thread on the clevis will be longer. When I set up my models I set the servo arms to 90 degrees, then I set the control surface to level (aileron/flaps/elevator/rudder) with the adjacent surface (wing/wing/horizontal-stab/vertical-stab). The rod must fit between those two points, plus the length of the threaded clevis. This is the easiest way to envision what length of rod I'll need.
The control rod's connection to the servo arm is fixed, because it's a simple 90 degree bend. The variable is the clevis' connection to the control horn, since that is threaded on and its total length can vary, hence for example both the Aileron and Rudder using 70mm long pushrod lengths to achieve slightly different *total* lengths. The reason why we don't specify *total* assembled pushrod lengths is because some pilots may choose different holes in the servo arms, which will change the total length. Accordingly, the length of the metal pushrod is the only constant, since those are cut at the factory.
In summation, on the Hornet next to me, the *total* distance between the centerpoint of the outer hole of the servo arm and the centerpoint of the ball link control horn is about 84mm for Rudder, 88mm for Aileron, 78mm for Flap, and 53mm for Elevator.
This is how I like mine. Other pilots may vary according to their control authority preferences on these bigger jets.
