New Avios Mig 17 ?
Originally posted by Evan D View PostMy preference... I have a dozen and use them in 70-90mm 6S and 80-90mm 8S with a 2 cell. Love them and they are small and light.
https://www.rcjuice.com/lipo-batteri...o-battery.htmlCheck me out on youtube at https://www.youtube.com/user/gooniac33
Assembly completed. Some minor issues easy to fix but they could have saved me about an hour of fiddling with the inner gear doors by putting one line of instructions in the manual. Added pilot from crashed Mig 21. I decided the flimsy foam tail skid might last about one flight so a friend 3D printed me up a new one. The lightburner kit was an easy install and looks great. The hardest part was routing the wire. Balanced on the indicated CG with the battery all the way fwd plus 2.5oz wt. Maiden maybe Fri?3 Photos
- Likes 2
Originally posted by Capt G View PostAssembly completed. Some minor issues easy to fix but they could have saved me about an hour of fiddling with the inner gear doors by putting one line of instructions in the manual. Added pilot from crashed Mig 21. I decided the flimsy foam tail skid might last about one flight so a friend 3D printed me up a new one. The lightburner kit was an easy install and looks great. The hardest part was routing the wire. Balanced on the indicated CG with the battery all the way fwd plus 2.5oz wt. Maiden maybe Fri?
What's the recommendation for the timer using a 5000mah battery, for mixed-throttle use? Should I set it for 3.5 mins?
It looks to me like longer times might be OK since this model doesn't need full throttle all the time.Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Originally posted by themudduck View PostWhat's the recommendation for the timer using a 5000mah battery, for mixed-throttle use? Should I set it for 3.5 mins?
- Likes 2
Originally posted by Capt G View PostAssembly completed. Some minor issues easy to fix but they could have saved me about an hour of fiddling with the inner gear doors by putting one line of instructions in the manual. Added pilot from crashed Mig 21. I decided the flimsy foam tail skid might last about one flight so a friend 3D printed me up a new one. The lightburner kit was an easy install and looks great. The hardest part was routing the wire. Balanced on the indicated CG with the battery all the way fwd plus 2.5oz wt. Maiden maybe Fri?Marc flies FW & FL: AL37, MiG-29, T45,F4, A4, A10, F104 70 and 90, P38, Dauntless SBD, Corsair, B17, B24, B26 & P61, Lipp.P19, ME262, Komets, Vampire, SeaVixen, FMS Tigercat, FOX Glider & Radian XL.
Ok now that I have gotten the rest from all the flying and other duties... the Mig will be completed and run up tonight!! its mostly done but I need to get the final prep done for the maiden this weekend. Servo adjustment, gear doors and clear coat... Really looking forward to this bird! I have seen them fly already but its always best when you get to fly your own...Check me out on youtube at https://www.youtube.com/user/gooniac33
Mine arrived this morning and I've just finished with the unpacking, examining all the parts and testing of all the servos. I'm happy to report that all servos tested positive on a servo tester for several cycles. The only flaws (though very slight) were minor warpage in the flaps (or wings) as pictured below. Not a real big deal as I've seen far worse and this will be easily massaged straight. Also, noted was the wooden hold down for the ESC came loose, resulting in the ESC flopping around during shipping and pulling the 3 wires to the motor out. Reconnected, test for proper rotation, repositioned the ESC, glued the wood piece back down, a little hot glue along the edges of the ESC to keep it from moving. Will build when the rains come this weekend.
So far, this model appears to be just as good (initial quality) as any of the Freewing and FMS planes I have. If it goes together and flies as well as other private owners have indicated, I think HobbyKing has another winner. They even seem to have gotten the release process right this time (still thinking about the C-130 fiasco). After the many "losers" that have passed through my hanger (of all makes), I'm hoping it will join the fleet of "winners" from HK - BushMule, C-130 ("V2"), Albatross.
Originally posted by xviper View PostI see some people set up the airbrakes differently. Some have them tied to the flaps, while others have them separate and operated by its own switch. What's the pros and cons of each? Also, at what point would you activate the airbrakes?
Originally posted by Quickstop View Post
Speed brakes are pure drag while flaps are extra lift with drag. I would only put them on separate channels, sometimes you won’t want the extra drag and putting them together, you have no choice.
Well I made some really good progress on mine last night. Got the linkages all lined up as they should be and noticed that the rudder halves were going in separate directions. This could be what is causing the rolling on some of the planes. Be sure to check this stuff before tou get it flying. Yes you can trim it out but the plane will still handle funky this way. I had to bend mine but it was easy to do. I also had to remove a couple servos to get them centered properly since the linkages were not enough. Either way it got done. I also did my first coats of clear and really like how it came out! Will do a lil more work today which will include securing esc/wires, installing ec5 plug and ztw UBEC. Will hopefully have it ready for maiden this sunday... here are pix of what I did...
Originally posted by RanGee View Post
The Mig's stock power system is very efficient, you should be okay with 4-5 minutes of mixed throttle. I flow mine (mixed throttle) for 4 1/2 minutes and landed with 43%
@ Tengarng do you mind elaborating how your setup of how the BEC is connected in your setup? I like the idea of extra insurance, but not 100% clear how you went about it, since have a few of those 2s packs floating around and could be put to good use.
