Hi, everyone.I've recently gained access to a tarmac strip (quiet road!), and was thinking about fitting undercarriage to my 64mm Sabre. Does anyone have any ideas about fixed or retracts, and any alternative sets that may fit the 64mm Sabre, please? Thank you, Den, Cymru.
sabre 64mm undercarriage?
Originally posted by denvoyager View PostHi, everyone.I've recently gained access to a tarmac strip (quiet road!), and was thinking about fitting undercarriage to my 64mm Sabre. Does anyone have any ideas about fixed or retracts, and any alternative sets that may fit the 64mm Sabre, please? Thank you, Den, Cymru.
Thanks, Valkpilot. I have a set of P15 u/carriage, so I'll look into that. The second set from Porcupine will not be possible, as US postal charges would rocket the price up to a few thousand dollars!JJ! The problem with the Sabre is there is no Rudder, so a steerable nose-leg would be desirable, unless I have I fit of patience, and an extremely wide road to take off from! It's marginal, because it's pretty good from a hand launch. Keep safe, Den, Cymru (Wales)
Originally posted by denvoyager View PostThanks, Valkpilot. I have a set of P15 u/carriage, so I'll look into that. The second set from Porcupine will not be possible, as US postal charges would rocket the price up to a few thousand dollars!JJ! The problem with the Sabre is there is no Rudder, so a steerable nose-leg would be desirable, unless I have I fit of patience, and an extremely wide road to take off from! It's marginal, because it's pretty good from a hand launch. Keep safe, Den, Cymru (Wales)
