In my opinion, it appears to have good performance on the new motor. I flew an older one on both stock and the FMS90mm fan. I prefer this 1650KV myself.
And for the record, it IS stock.
As far as flight time goes, I hit the pattern at 2:00. I roll up to the bench at between 2:30 and 3:00 depending on if a go-around is in order due to wind usually.
With mixed throttle you can land at around 30% remaining. If you are heavy in the throttle the whole time, you will land at about 15%.
