Official Freewing 90mm T-45 Goshawk Thread
  • Originally posted by seaviper View Post
    A flight from yesterday. It was really windy at altitude. A thunderstorm was approaching from behind the camera. On this day, landings were a challenge. But she made it home safe.
    A friend got his plane stuck in the big tree at the end right after this flight. Then it rained.
    Edit: slats and half flaps on landing due to wind.
    thanks for sharing Part 2
    Looks like the motor is much more powerful based on your flight.
    Rich
    • As a side note, it appears this V2 version of the T-45 is using the same retract units as the new Hornet, 5.1 mm shafts, type E and type C. Better retract if you ask me. Also the MCB-E can be found on the Hornet page as well.
      • seaviper, I've reached out a couple of times to MRC via chat and have also created a 'support ticket', regarding whether or not placement of an order for a new T45 will result in one receiving a 'V2', and they've not replied in over a week. The one input I got was essentially 'That's not a small task/question to answer', so I'm a bit hesitant pull the trigger. Usually, their support is nothing short of incredible, so I don't know what's producing the 'relative silence' on this particular inquiry. Did you simply place an order and receive an aircraft with the updates? THANKS FOR ALL YOUR INPUT!
        • Originally posted by sky_hawk View Post
          It sounds like they are not at the warehouse or do not have a way to verify what's in stock. I would assume that you would be getting the newest stock, my V1 is over 1 1/2 years old now
          Rich
          • That's probably true. Thanks for the reply, Rich!
              I decided to order the new V2 1650 motor and I am going to hold off flying until installing it.
              Thanks for all your information
              Rich
