I somehow set the brake on one of my escs when trying to calibrate it seams the f7r and the b24 are different any help?
ESC problem f7f
FlightLine F7F-3 Tigercat 1600mm (63") Wingspan - PNP - FLW302P The Grumman F7F Tigercat is a twin piston engine aircraft developed during World War II. Originally envisioned as a carrier-based naval fighter, the Tigercat underwent several iterations and was later optimized for a variety of roles. Although World War II
theres an esc manual for the plane on this page.
First, the Tigercat is a 2 engine plane and the Liberator is a 4 engine plane, but the principles behind their ESCs are the same. You must have attempted to calibrate in a way that the engines initialized at different times or you waited too long on the one that you set the brake on. Isolate the one that you set the brake on (ie, disconnect the other one) and use the manual instructions to turn the brake off.
