I was thinking about what the next generation of our foam models might come equipped with somewhere in the future. So consider this a wish list more than anything for fun. I will start with a hypothetical bullet list of features...What do you think? What does yours look like?
- NEW! Revolutionary "Quick Connect" servos and electric retracts! No more digging out and re-installing servo leads throughout your model to replace a faulty unit. Simply select the quick release button to remove or "snap" into place to install.
- NEW! Fully detailed scale plastic cockpit! No more foam cockpits that are prone to gatoring in the sun. The cockpit is entirely made of plastic with outstanding scale detail. No 3DPup aftermarket parts required.
- NEW! Highly detailed scale pilot. These molds are extremely detailed and painted. No need to hunt for the perfect scale aftermarket pilot. He's already in place! (Servo-activated head optional as an upgrade)
- NEW! "Virtually Unbreakable" Struts and Retracts! These new struts and retracts can withstand the forces of even some of the worst landings and accidents. The metals used can take abuses never before seen in the hobby without any damage.
- NEW! Our Patented "LiPoPLUS" technology has improved flight times tenfold from old tech LiPos without added size or weight. What used to be 3 minutes of flight time is now 10+ minutes!
- NEW! XTP Foam has removed any sign of cell structure. The surface appears as smooth as plastic, resists heat damage with no texture visible to the eye. Accepts any paint including lacquer!
