Re: 1400mm T28
Envelope-to: ml-node+s1075610n4823h12@n5.nabble.com
Delivery-date: Thu, 16 Oct 2014 05:45:34 -0700
Received: from s09.etcserver.com ([216.144.247.66])
by sam.nabble.com with esmtp (Exim 4.72)
(envelope-from <ron@mightyduct.com>)
id 1XekQv-00079s-VF
for ml-node+s1075610n4823h12@n5.nabble.com; Thu, 16 Oct 2014 05:45:34 -0700
DKIM-Signature: v=1; a=rsa-sha256; q=dns/txt; c=relaxed/relaxed; d=mightyduct.com; s=default;
h=Content-Transfer-Encoding:Content-Type:MIME-Version:To:From:Subject:Date:References:In-Reply-To:Message-ID; bh=O0gizxbZB+kXjQF4UNtAc9///9LFGyIWqQG6AArH/c8=;
b=vgA7Kwqo5HWofyVVCp5YFYbDPt/rInmbu2FEtvZVetvjpU9IaBTLPUJ3yeE0N7LluNig0gGVZeeMJ RtrqvJIWi58Gh3nVVva3LLHnhiNOS07WWjNJ8DnmdxIGVsTUPe 57Y2B+gyD4flyLD1uqNHvLOP2fWdZgBKnFEySnqfW3ZA=;
Received: from localhost ([::1]:46496 helo=s09.etcserver.com)
by s09.etcserver.com with esmtpa (Exim 4.82)
id 1XekQq-0005ML-Fc
for ml-node+s1075610n4823h12@n5.nabble.com; Thu, 16 Oct 2014 07:45:28 -0500
Received: from 50.177.216.134 ([50.177.216.134])
(SquirrelMail authenticated user ron@mightyduct.com)
by s09.etcserver.com with HTTP;
Message-ID: <7d02c912ca0e3f0ce21ba9cd4e0d845d.squirrel@s09.etc server.com>
In-Reply-To: <1413457738381-4823.post@n5.nabble.com>
References: <1391527867472-1651.post@n5.nabble.com>
<1391546682919-1652.post@n5.nabble.com>
<1413358118590-4781.post@n5.nabble.com>
<1413376737569-4783.post@n5.nabble.com>
<1413377474528-4784.post@n5.nabble.com>
<1413378869619-4785.post@n5.nabble.com>
<CAHzBzGEh-4OMTmxOHy5y9n+Ur8rv0pQuo6EDACHkqNCF=09RtQ@mail.gma il.com>
<1413383185358-4789.post@n5.nabble.com>
<1413397276703-4801.post@n5.nabble.com>
<1413414016639-4812.post@n5.nabble.com>
Date: Thu, 16 Oct 2014 07:45:28 -0500
Subject: Re: 1400mm T28
To: "Chris_UAE [via Motion RC Forum]" <ml-node+s1075610n4823h12@n5.nabble.com>
User-Agent: SquirrelMail/1.5.2 [SVN]
MIME-Version: 1.0
Content-Type: text/plain;charset=iso-8859-1
X-AntiAbuse: This header was added to track abuse, please include it with any abuse report
X-AntiAbuse: Primary Hostname - s09.etcserver.com
X-AntiAbuse: Original Domain - n5.nabble.com
X-AntiAbuse: Originator/Caller UID/GID - [47 12] / [47 12]
X-AntiAbuse: Sender Address Domain - mightyduct.com
X-Get-Message-Sender-Via: s09.etcserver.com: authenticated_id: ron@mightyduct.com
X-SA-Exim-Connect-IP: 216.144.247.66
X-SA-Exim-Mail-From: ron@mightyduct.com
X-SA-Exim-Scanned: No (on sam.nabble.com); SAEximRunCond expanded to false
Hi Chris,
I have the 1400mm P51 not the 1700mm. During take off with no flaps, just
some elevator and a touch of rudder works great. When I take off with
flaps down the tail wheel lifts off first. I don't like that because a
small gust of wind could drive the prop to the ground. That's why I don't
usually take off with flaps.
Taking off with no flaps works great for me. The tail wheel stays down and
I don't need the extra lift. She takes off in a short distance.
Happy Landings
Let us know
Ron
On Thu, October 16, 2014 6:08 am, Chris_UAE [via Motion RC Forum] wrote:
> Thanks for sharing that info..it is a very helpful to me. Hopefully I
> will be receiving my P51 1700mm this evening (the yellow Ferocious
> Frankie), as
> excited as I am ...I am also very intimidated by this plane. I have flown
> EXTRA 300's, PT17 Strearman, low wing balsa wood semi aerobatic planes
> but the P51 to me seems like a whole different ball game. Questions: On
> take off, does the P51 require an initial elevator down, just to get the
> tail up or will a bit of the lowered flaps do the trick? I have hear that
> this plane can nose over without the initial elevator down on take off. I
> would have a few sleepless nights if I crashed on my maiden takeoff..
> Please advice the right process / approach in doing initial flights with
> this baby. Although I will look at flying her only after I have completed
> a lot of successful flights on the T28 1400mm
> _______________________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://motion-rc-forum.1075610.n5.nabble.com/1400mm-T28-tp673p4823.html
> To unsubscribe from 1400mm T28, visit
> http://motion-rc-forum.1075610.n5.nabble.com/template/NamlServlet.jtp?mac
> ro=unsubscribe_by_code&node=673&code=cm9uQG1pZ2h0e WR1Y3Qu
id 1XekQv-00079s-VF
id 1XekQq-0005ML-Fc
MIME-Version: 1.0
Hi Chris,
Happy Landings
Let us know
Ron
> Frankie), as
> below:
