Model Aviation Magazine
FMS Flap servo question
  • FMS Flap servo question
    i need a servo suggestion for Flaps for my FMS T-28. i guess i need 1 positive & 1 reverse ?
    Re: FMS Flap servo question
    I assume this is on the 1400mm version? I have actually used eflite servos for some of my FMS birds that needed a servo replacement. Im sure some hitec servos of similar size will work just fine. Also if you are having a problem getting them to be opposite you could also buy a reverser Y harness and that way one will be different. Make sure you check to see if the servos are both sitting in the same direction on the wings for the flaps. If they are on then they probably wont need a reverser.
    Coot
      Coot, that's exactly right. If the flap servos are in there pockets facing the same way a reverser won't be needed.
        http://www.motionrc.com/fms-1400mm-t-28-9g-flap-servo/
        Check this out. It's the slowed down flap servo exact replacement.
          thanks for the info guys. due to the mounting...gonna have to reverse one.
          i do like those slower servo's !
            With My Jr 9503x or 11 Tx , you have the option of "delayed" flap movement , with various delays in seconds
            I think some of the other Tx's on the market , have this feature
