National Air and Space Museum
Eflite Carbon z T28 repaint
  • Eflite Carbon z T28 repaint
ID:	150864Click image for larger version  Name:	20180619_035106.jpg Views:	1 Size:	127.5 KB ID:	150863 Taken from a plane in the Kalamazoo museum in Michigan. Click image for larger version  Name:	Screenshot_20180621-190013_Gallery.jpg Views:	1 Size:	79.8 KB ID:	150862
ID:	150869Click image for larger version  Name:	20180622_190425.jpg Views:	1 Size:	112.8 KB ID:	150867Click image for larger version  Name:	20180628_184226.jpg Views:	1 Size:	119.5 KB ID:	150868
        Painted chrome not good. Click image for larger version
          Flight Metal is much better look ,worth the time to apply. Click image for larger version
            Clear coat going on Click image for larger version
ID:	150878Click image for larger version
ID:	150879Click image for larger version
              Turning out pretty good! Did you notice some rough texture on the foam surface when you peeled off the factory decals? I am playing around with different methods of painting foam and I can't get around how bad the foam surface looks when the decals are removed.
ID:	150887Click image for larger version
ID:	150888Click image for larger version  Name:	20180904_220821.jpg Views:	1 Size:	87.7 KB ID:	150886
                  Really stellar workmanship, T33jetman! The Flitemetal is an especially nice touch.
ID:	150891Click image for larger version
ID:	150892Click image for larger version
                        • #13
                          Beautiful my friend! Absolutely! And alpha go to eflite and crack some heads on them discontinuing this and all the sweet carbonZ planes!
                          • #14
                            https://m.facebook.com/story.php?sto...00000760474843
                            • #15
                              • #16
                                Sweeeeet plane my friend!
                                • #17
                                  Very nice. What lighting system did you use?
                                  Mine is grounded due to a failed gear. Flew it one day, and it was fine. Put it together the next and one of the gear was inop. Waiting for replacement to get in stock. Or if anyone knows of better replacement gear I'd love to know.
                                  Beautiful job
                                  • #18
                                    • #19
                                      I know what I will be watching during my lunch break today! I am looking to improve my method of painting foam before I repaint my new E-Flite Cherokee. I had good results in the past on foam, but repainting my Parkzone Archer this summer didn't turn out well. It was bad enough to make me rethink my methods before attempting the Cherokee. Painting white seems to be the biggest issue. I had been using the natural foam in the past instead of painting white over it. The Archer was the first time I decided to paint the entire plane white and that is when I realized I wasn't happy with the results. Painting other colors over already painted foam (example would be the red tails and wing tips on an OD B-17) turned out very well. White over natural foam turned out horrible. Greatly looking forward to your video as your results indicate you are one that I can surely learn from!
                                      • #20
                                        Fantastic job! Can't believe they discontinued this plane.
