Originally posted by Lowknifedge
View Post
Originally posted by sethscorsair View PostMy prop is slightly wobbly so I tightened the screws in some more but I haven't balanced it and don't have a balancer does everyone here balance there props or do some just fly as is? My two eflight planes I've never worried with.
Each blade must be seated properly. It's only when they aren't that you might get a wobble. Also, there are short screws and longer screws. If you mix them up, they won't bite the same and maybe that's why you're getting a wobble. Finally, you may not have "worried" about your 2 Eflite planes but that's an exception. You should ALWAYS worry about prop balance. Even the smallest imbalance (although not noticeable) can, in short time, cause motor mounting screws to work themselves loose or even strip the threads in the screw holes, not to mention wrecking the motor bearings before their time.
- 1 like
I just completed mine today and it's ready to be hung up for another 2 months or so when spring finally gets here. The quality of this plane is superb, one of the best I've seen (and I've seen 150 of them). Everything was very well designed and thought out. The only thing that caused me alarm was that one wing, the retract and gear door were plugged into each other's slot. It was a bit of a shock when the retract started to close on the closed doors. With the help of my servo tester, I was able to fairly quickly figure out where they went based on the supplied diagram even though the diagram was backwards. It wasn't hard once I saw which end the lights (2 pin vs 3 pin) were on the wing board.
I've decided to fly it with the stock 3-blade prop instead of the 4-blade from the FMS 1700mm Corsair. The hex hole was too big (on the FMS prop) to fit over the hex nut on the stock prop shaft base and the shaft was too short to allow me to use the FMS washer, nut and nose cone. I could have clamped the whole thing down with the stock nut but there wouldn't be enough shaft left to attach the stock nose cone and I like the clean look of the nose cone. The FMS prop adapter holes were not the same as the stock one, so it wasn't even possible to swap prop adapters. I'm not sure how TI made it work.
Originally posted by xviper View PostYou don't balance them in the traditional sense (at least, I don't). You weigh each blade and make sure they are all the same. You used the 2 triangular metal pieces in the correct places, right? Mine were all spot on 40.0g each. The central hub is compact enough (small radius) that any slight imperfects won't equate into large imbalances. If you are worried about it, put it together with all the bits marked to where they go back when assembled with the blades and balance just the hub on a prop balancer. You can use small blobs of hot glue in the light spots. If you put too much glue, cut is down with a razor.
Originally posted by Crazystick View PostI have the Birdcage an when I received it the wires coming from the tail and rudder servos were disconnected . Can someone take e photo of the blue box to show where these servos are connected .
Thanks , Crazystick
https://www.motionrc.com/products/fr...ol-box-e-mcb-e
Originally posted by Dcheli View PostMy prop balanced perfect right out the box. Still snowing here in Western Washington, looks like for another week maybe. Not normal!!
As for my props they also balanced perfect out of box. I was surprised. I almost always have to balance props out of the box. Another pleasant surprise with this model.Aros.MotionRC
Motion RC Website/Advertising
Self-Admitted Warbirdaholic
My RC videos on YouTube:
“My soul is in the sky.”
- 4 likes
I did the usual prop balance for this build type. Weighed each blade on a jeweler scale after cleaning the edges first. This was the closest in weight yet of all my FL warbird props and in spite of making them all match the lightest blade by sanding the two heavier blades, I could have probably just put it together and run it, the blades were that close. Already performed a full power test and amp draw run up. Smooth as silk in all rpm settings.
Yes, these blades just keep getting better!
- 1 like
Originally posted by Aros.MotionRC View PostCurrent Hanger: Flight line 1600mm Spit ( Clipped ) FMS 1400mm 109, Durafly 109, Eflite P-47, Eflite PT-17, UMX Pitts, UMX Timber, Twisted Hobby Extra, Extreme Flight EDGE, FREEWING, A-4, Avanti, A-10 , F4. Byron T-6, Top Flite P-47, H9 Corsair, Ziroli Hellcat. Jeti DS16 Carbon /Spektrum DX8, Freewing F-14
Just arrived: Freewing F-22,On the way: Flightline F4U Corsair
- 1 like
Aros.MotionRC
Originally posted by Dcheli View PostMy prop balanced perfect right out the box. Still snowing here in Western Washington, looks like for another week maybe. Not normal!!Captain: Got any ideas?
F/O: Actually not.— Captain Chesley B 'Sully' Sullenberger III and F/O Jeff Skiles—
- 2 likes
Originally posted by Elbee View Post
Dcheli, Off topic and my apologies. What is 'normal'? The earth is reported as being 4.6+ Billion years old. We have been recording weather for less than 5,000 years with the official recording of temperatures for 135 years. A quick division equation of 135 years as a percentage of 4.6 Billion years = 2.97160467e-8. Whatever that number is it is so small as to not even be considered as a statistical sample large enough to translate into any useful sampling in determining 'normal'. As for what is normal, I presume you are writing about what is a mean occurrence or are you thinking average occurrences in your lifetime? My point is obvious, there is no normal weather, it is just the weather. A forecast is simply that, a forecast for the future. Might be close, but never completely accurate. I always check, recheck, and check again before I take to the skies for that reason, it is a forecast, i.e., prediction of the future, there is no normal. Respectfully, LB
Sorry about the off topic, Hey Elbee, what's the best most reliable thing to mask a clear canopy with prior to a repaint?
Long live the Flightline Corsair!
Best Regards
Woody
technically I wrote all that. The comment stems from an error I made and the logic lesson I then learned as a young man and it stuck. Some of my training and education is in logistics and statistics, so I tend to balk at how words are used.
Woods, I actually don't mask the canopies, I have one of those 'Superman Vision' lighted visors and paint mine by hand. There was a post in the Phantom thread about a liquid masking film product that got my attention. I'll find it and post it to you with the info. Best, LBCaptain: Got any ideas?
Woods, this is the product https://www.amazon.com/Grafix-2-Ounc...gateway&sr=8-5 Best, LBCaptain: Got any ideas?
Originally posted by Elbee View PostWoods, this is the product https://www.amazon.com/Grafix-2-Ounc...gateway&sr=8-5 Best, LB
Best Regards
Woody
