Bunker 27 - USAF Veteran Owned Apparel Company
RocHobby Strega P-51 2 Blade Speed Prop ??
  • RocHobby Strega P-51 2 Blade Speed Prop ??
    Hoping the RocHobby Strega P-51 2 Blade Speed Prop will available soon. Hopefully not vaporware. Please!!! otherwise will be dropping a PW25 1250 KV and a swing 9x9...
    Re: RocHobby Strega P-51 2 Blade Speed Prop ??
    Have read on rc groups of cutting down a 12x12 to a 11x12. They talk like it works well.
      i am hearing a 11x12 prop works well......
        11 x 12 is the correct size. We had hoped to have a prop which would fit the stock spinner but it is turning out to be a problem. We may end up using another spinner, another motor shaft (without the hex drive nut), and finally the 11x12 prop. We had hoped it would be simple but this is not turning out to be the case.
