  • I've got to pull the wings too. I know I'll be a nervous pilot on the next flight. I don't want to lose this one, looks so good in flight.
    • Might be worth replacing the electronics that are giving you a problem. I personally wouldn’t trust it if you had to bend the pins to get a good connection. Sounds like it may be a weak point that could go bad when you least expect it.
      Just playing it it safe in my mind.
      • Yeah I would agree with Wolf on that one, maybe a new board in the fuse, it would be worth the 10 bucks of insurance
        • Yeah, after thinking about in bed last night. I think I'm going to replace the bullet connectors with something more positive.
          • got the plugs on the way so I can run the batteries and ESC's in parallel, just makes so much more sense.
            I need to improve my soldering skills again before trusting them with my airplanes. It was okay when wiring new pickups in the Strat, worst I'd get was a buzz or nothing at all. Not so with airplanes!!
            • Good deal, I think its tons better than just the battery per side setup
              • Yep, you get to thinking about trying to trim and fly when you lose a motor, not a lot of fun there and probably a heap of crushed foam to donate to the garbage can.....
                Nah, the plugs are the way to go, call it cheap insurance. I've already had two batteries pack it in due to a dead cell, fortunately both times were in a single engine plane and I managed to land safely.
                • This is true
                  • Got my plugs today, now running the ESCs and the batteries in parallel. Good call CB!!
                    • https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                      https://www.motionrc.com/collections...rallel-adapter
                      This is what I used to get everything working correctly.
                      • That'll do just fine, did your tigercat not come with xt60s though?
                        • Mine has deans
                          • Wow all the new ones I guess come with the xt60s
                            • Mine had/has Deans
                              • Yeah mine that I just bought has xt60s
                                • Mine also came with XT60's, but I converted them to Deans as all my batteries are Deans.
                                  • I didnt notice if there was an option to pick a perfered connector either
                                      No option, the early ones had Deans/T connectors and now the newer ones have the XT's.
                                      The Deans/T are basically crap connectors and really should not be used on anything above 3S
                                      ScaleTech OV-10 Bronco; HSD A1 Skyraider; FlightLine: F7F-2D, P-38 Allied Green, Sea Fury; FMS 1400: P-40B, P-51 Marie, F4U Olathe, F6F, T-28, P-40E, 1500 Razor, 1700 F4U and a Fox glider; Freewing: A-10(RIP l/g parts used A-26), A-6, P-51 Iron Ass; VQ: P-39, JU-52; LX PBJ-1(B-25), P-40E; Dynam: ME-262, FW-190, Waco, Catalina; Phoenix Spitfire; Maxford Antonov AN-2; Starmax L-4 Grasshopper; Eflite 1100 T-28 float; Tech1 P40; NP O-2 Skymaster; ASM A-26 Invader; ESM F7F-3
                                      • I do agree with that.
                                          I agree with OV10, and I'm sorry I converted mine to the Deans.Whenever Motion gets the XT's back in stock, I will convert all my Equipment to them.
